High power setup for the H122D!
For those who are concerned about the FPV and flight control range for the H122D. We are coming out with an easy setup to get better range.
Follow the detailed instructions shown in the tutorial video in the below link
- GermanDroneGuy
Re: High power setup for the H122D!
Hey Hubsan! Thanks for this great info! It would have been better if you'd given the information (what the high power mode does) in the video discription. This caused some confusion
Flying drones for a while now and started making videos about it this year.
https://www.youtube.com/channel/UC5BFuz ... 4fEmqGyTw/
Thanks for your good idea!the high power mean that you can get better fly range and video transmission in this operation.
H122D high power setup ,which increase video transmitter signal for stronger video signal at long range.
Also can extend the controlling rang by increase 2.4gHz output signal strength.
- GermanDroneGuy
Thanks for the clarification, Ailsa! I have one question though: Can you tell me the Signal strength (in mW) with and without the high power mode?
Hello Hudson... very important setting. Thanks!
If Hubsan uses the standard outputs It will be 25mW in regular mode and 200mW in high power mode. Do note that that will use more batteryGermanDroneGuy wrote: ↑Fri Apr 20, 2018 3:17 pmThanks for the clarification, Ailsa! I have one question though: Can you tell me the Signal strength (in mW) with and without the high power mode?
This info helps alot thanks for bringing this up and answering as well guys!
I apologize for going off topic but im trying to post a new topic and i cant seem to find where that option is. I was going to send a private message about this to an administrator but apparently i cant send private messages until im more active... Which i cant be due to not knowing where this "new topic" tab is. Any help would be appreciated, thanks.
