hi
just purchased a new H501ss and am experiencing problems with circle me and follow me
neither of them work
long press of the Video button just stops the video and downward press of rt stick shows follow me mode but the drone does not move.
tried taking GPS mode off and the drone just started flying away
thanks
Circle me and follow do not work
Re: Circle me and follow do not work
would you mind to show the firmware version of your drone for us?Thanks
hi
i checked with the information on the FB page its ok but :
V4.2.28
LCD V1..3.4
501ss V2.1.29
FC V1.1.41
CAM v30.84.84
thanks
V4.2.28
LCD V1..3.4
501ss V2.1.29
FC V1.1.41
CAM v30.84.84
thanks
Hi ya, make sure you keep the gos on. But also make sure you put the drone to its recommended height and distances for the modes, it should pop up on the screen before you activate it.
ATB Marc
ATB Marc
Hubsan Quadcopters In My Collection So Far:
Hubsan X4 Desire Pro H216A
Hubsan X4 H107C (a few of them)
Hubsan Q4 Nano H111
My Youtube Channel:
https://www.youtube.com/channel/UC9nFqm ... GWmyLnCQ5w
Hubsan Q4 Nano H111
My Youtube Channel:
hi all
i have made sure distances were ok and follow me will work intermittently. cant say i like having to depress throttle while pressing down right stick to enter the mode but can not get circle me to work at all
Hello,for the follow me and circle function,the drone should be at least 10 meter from the transmitter.
If not mistaken there is a height limitation for these to work. If you are too high the initiation of this option will cancel. It will also cancel if you use the joysticks to adjust height or direction after starting either one of them.Hubsan-Ailsa wrote: ↑Wed Jul 04, 2018 8:21 amHello,for the follow me and circle function,the drone should be at least 10 meter from the transmitter.
Try flying H501S 10 meters away and no more than 20 meters high in a clear field to test again.
My H501A followed and circled me at 10 meters and 20 meters high until I moved the sticks.
