Hi! I had a strange situation!
I set the shutter to 1.6 seconds, and also higher values. The application pauses for a while, then displays what the result of the photo would be, but when I open the files on the computer, no image has been saved. I've already tested giving the command through the radio and the application and the same thing happens.
Other images, in automatic mode for example, and videos save normally.
Zino Mini Pro long shutter not storing image
