Recover recently deleted?
So on the media section of the Zino 2+app if you press the delete button on accident it doesn’t ask you to confirm that you want to delete it and just deletes it automatically with one push. And I can’t find a recently deleted folder so I’m wondering is there a way to recover an accidentally deleted video or photo?
Re: Recover recently deleted?
In the old days the way a hard drive made a file deleted was change the name but every part of the file was still there with just one character of the name changed to make it nt appear as a file leaving the space on the drive it occupies as available to be written over. If you know the naming characteristics of the memory and your drone allows searching the picture memory possibly the file is recoverable.
I think the old computer deleting way was putting an asterix at the beginning of the file name so as long as you knew thee eextertion like jpg or jpeg you could get results of all jpg's deleted that you'd see with an asteric at the front of the file name by search for thee files using the search term wildcard of an asteric for the whole name like *.jpg but in your case just try wild cards for name and extertion. Or if the current versions of CMD promp DOS allows the command undelete go for it.
Try this video.
https://youtu.be/0SiTGVhWqT8
Try this video.
