Wifi standard of smartphone for zino
Posted: Sun Dec 27, 2020 3:00 pm
by Nathoms
I learned that you need the 802.11ac wifi standard to be able to connect your smartphone to a 5Ghz drone. Mine doesn't have it so I wanted to ask you if having this standard is mandatory with a Hubsan h117s zino or a zino pro because I know that the smartphone is directly connected by cable to the radio. And if this wifi standard was mandatory, then what's the use of this famous cable that connects the two?
Thank you !
