hubsan 501a
Posted: Wed May 23, 2018 2:36 pm
I lost my Copter 501a shortly after the start. Start was OK, flight a short time as well.
Then suddenly the drone was no longer controllable.
The headless mode had failed at a distance of about 300 meters and 63 meters in height
and the copter was no longer controllable. He flew up and away.
Conclusion:
The stability of the satellite reception of the copter is not good (Transmitter 11 satellites, Copter less than 8 satellites)!
The automatic return function did not work!
The copter may also have lost the binding due to the distance or the crash.
A lasting bond, with again finding within reach would be desirable.
The copter is no longer findable, very bad!
Regards Juergen
Conclusion:
Regards Juergen
