Hello, Flying my 122 D for the first time, when I throttle up in small increments the drone does not hover, instead it keeps going up.
If I throttle down to hover it keeps going down until it bounces on the ground. It eventually lands with the props still turning. The calibration feature does not help. All other phases of operation appear to work. Any ideas? Thanks
H122D X4 Storm" bounces"
Re: H122D X4 Storm" bounces"
It's normal,because there is no altitude position hold function for the H122D. so the drone will not hover when you release the stick.
I too also am finding this to be a small issue. Light throttle feathering in either direction vertically seems to be the best way to "hover" with this model.
- magicmannst
watch some racer vids. you'll see why there is no altitude hold.
Qualcuno sa il perché dopo aver cambiato la scheda , il radiocomando non si associa più ?
