High power setup for the H122D!
Posted: Tue Apr 17, 2018 2:37 am
For those who are concerned about the FPV and flight control range for the H122D. We are coming out with an easy setup to get better range.
Follow the detailed instructions shown in the tutorial video in the below link
Re: High power setup for the H122D!
Posted: Thu Apr 19, 2018 1:30 am
by GermanDroneGuy
Hey Hubsan! Thanks for this great info! It would have been better if you'd given the information (what the high power mode does) in the video discription. This caused some confusion ;)
Posted: Thu Apr 19, 2018 6:58 am
Thanks for your good idea!the high power mean that you can get better fly range and video transmission in this operation.
Posted: Thu Apr 19, 2018 11:09 pm
H122D high power setup ,which increase video transmitter signal for stronger video signal at long range.
Also can extend the controlling rang by increase 2.4gHz output signal strength.
Posted: Fri Apr 20, 2018 3:17 pm
by GermanDroneGuy
Thanks for the clarification, Ailsa! I have one question though: Can you tell me the Signal strength (in mW) with and without the high power mode?
Posted: Sun Apr 22, 2018 8:09 am
by jar
Hello Hudson... very important setting. Thanks!
Posted: Thu May 10, 2018 5:15 am
by Techdragonz
If Hubsan uses the standard outputs It will be 25mW in regular mode and 200mW in high power mode. Do note that that will use more battery :mrgreen:
Posted: Sat Jul 07, 2018 8:16 pm
by Frosty
This info helps alot thanks for bringing this up and answering as well guys! 👍
Posted: Sun Jul 08, 2018 1:19 pm
by Frosty
I apologize for going off topic but im trying to post a new topic and i cant seem to find where that option is. I was going to send a private message about this to an administrator but apparently i cant send private messages until im more active... Which i cant be due to not knowing where this "new topic" tab is. Any help would be appreciated, thanks.
