H501S heading and orientation
Adameck
Post by Adameck » Tue Oct 30, 2018 3:48 pm
Hi! My H501S shows heading orientation number which is compass orientation according to magnetic north pole. When I fly 200-300 m and I can't se my drone it's difficult to come back drone to me. I don't recognize which heading orientation is correct. Is it possible to show on screen heading according to my position - not magnetic pole? I know, when I turn RTH function, I will se correct heading number but Is it another solution to manually easy come back?
Drehweber
Re: H501S heading and orientation
Post by Drehweber » Wed Oct 31, 2018 2:38 pm
North is the best direction for flyers because there is no sun. When I start, I look north and I set the drone to north. Showing the transmitter position would be a nice feature, but don't you use fpv if u can't see the drone?
Post by justjarhead » Sat Nov 03, 2018 12:29 pm
If your 501s is white add accent stripe to front an rear so you can see direction it is pointing. Il loose mine in the clouds background every time I fly and am adding ted tape on nose and orange on rear to make visibility better. Heading to hard ware store now.t
