H501S heading and orientation
Hi! My H501S shows heading orientation number which is compass orientation according to magnetic north pole. When I fly 200-300 m and I can't se my drone it's difficult to come back drone to me. I don't recognize which heading orientation is correct. Is it possible to show on screen heading according to my position - not magnetic pole? I know, when I turn RTH function, I will se correct heading number but Is it another solution to manually easy come back?
Re: H501S heading and orientation
North is the best direction for flyers because there is no sun. When I start, I look north and I set the drone to north. Showing the transmitter position would be a nice feature, but don't you use fpv if u can't see the drone?
If your 501s is white add accent stripe to front an rear so you can see direction it is pointing. Il loose mine in the clouds background every time I fly and am adding ted tape on nose and orange on rear to make visibility better. Heading to hard ware store now.t
