Hello.
I bought a Hubsan H501S the one that comes with the advanced or professional remote but the screen flickers all the time. I tried all frequencies but problem remains. Is this a quality issue? or I am missing something?
Thank you
Heavy flickering in my advanced remote
Re: Heavy flickering in my advanced remote
Pst a video of what you are seeing.
Had a similar problem with a new H906A Tx.. I flew with it anyway and while in a hover, I looked down at screen and it was blank. a second or two after that, I noticed the LED on Tx was out and had no control of quad.. it was just sitting there hovering. I recycled power and LED came on but display still black but was able to land before LED went out again. After that, I was never able to get display to work and leaving power on would pull the LiPo Tx battery down fast and shut the Tx off. Moral: You probably shouldn't fly it like that or risk losing control of drone. I was lucky it was close when it happened.
I found the sma to fl connector wire inside my 906a was shorted out from factory due to excessive heat used during manufacturing process.I verified this by unplugging wire and using an ohm meter to check center pin to shield continuity , which should of course be zero.Mine was a direct short which was causing various issues with my fpv.I found an after market supplier for a replacement which cleared up my fpv issues.
