HUBSAN X4 H501S
Posted: Sat Sep 08, 2018 3:54 pm
by montypyphon
Hi there, i accidently put the wrong firmware on my drone, now one light flickers pink and one light flashes pink, they wont connect to the controller and when i try and update it just fails? any help? thanks!
Re: HUBSAN X4 H501S
Posted: Wed Sep 12, 2018 2:59 am
IS it a H501 or an H501ss?
What firmware did you load for Flight controller i.e what hbs file and wht hbs file for the RX portion.
We need to know what model H501 you have, ( Look in the battery compartment and if it says H501 Camera board(one below battery) then you need
H501SS FC 1.1.43 (is downward compatible) and RX 1.1.41 ( is downward compatible)
IF it does not say that on Camera Board (one below battery) then it is a H501S and you need,
FC !.1.36 (downward compatible) and RX 1.1.36 (downward compatible).
These can be found on FaceBook in Files Section of Hubsan H501 / H502 / H122 group, files section under file name H501S raccolta firmware. Thanks Andrew Wood for posting.
Follow upgrade procedure on hubsan@001 for more help.
https://www.youtube.com/watch?v=MeXPBxqCrRI H501S
https://www.youtube.com/watch?v=_yT4RunYjg0 H501SS
These vary depending on wherre you got tools and firmware but I advise the above firmware because it is backwards compatible.
