Settings Mode
Settings Mode
I cannot get into settings mode on h107d+ anyone help ?
Re: Settings Mode
Do you mean setting the Mode 1 or Mode 2?
Re: Settings Mode
I'm having exactly the same issue, can't enter 'settings menu'. The manual states, "Press down elevator stick for one second to enter settings status,..." but nothing happens at all. I've tried a few combinations and found that the left hand button that the manual say "No use now" actually does have a use, it enters recoded video playback and what looks like a system status with date, mode etc but all at defaults. Nothing seems to give any method to alter those.
Not having access to the settings menu means I cannot set date etc,. I cannot delete recordings or format the card (it does automatically format if wiped to DOS, when inserted)
It does fly and records video,.. and I can play the card contents back on a computer and save/delete files there so, Plus I have a button that shouldn't work but does,... half a win then?
