My son just got his first drone at saturday 18. After few flights very good one of the propellers just stop to work fine
See the video. Very sad with only two days stop working. and see some videos of others users with same issue.
Hubsan X4 Desire Pro H216A Motor after 2 days open
Re: Hubsan X4 Desire Pro H216A Motor after 2 days open
See the video at:
Did you check if the propeller is fine?Did you crashed the drone before?Kindly power off the drone and slip the motor by your finger to test if it is stuck.
The same thing happened to me 6 days after the first flight.
I found that the motor wouldn't start on it's own but if I give the prop a spin the motor would then kick in.
My "temporary" solution:
I took apart the prop that was not working and lightly taped it with a hard surface. As well as wiggled the motor shaft attached to the small gear. This seemed to make the motor start on its own more often.
My long term solution:
I think I am going to order a few replacement motors
Wow yeah seems quite common this doesn't it, same thing with mine but after about 30-35 flights (no crashes) but even 35 flights is not many..
I'm going to change the motor on mine, but if it happens again so quickly I might have to think twice about having this drone in my collection..
Hubsan Quadcopters In My Collection So Far:
Hubsan X4 H107C (a few of them)
Hubsan Q4 Nano H111
My Youtube Channel:
https://www.youtube.com/channel/UC9nFqm ... GWmyLnCQ5w
Hubsan Q4 Nano H111
My Youtube Channel:
