What does the GPS accuracy test test?
gjvo
Contact:
Post by gjvo » Wed Jul 25, 2018 4:36 pm
I wanted to test my H501M with waypoints today but the accuracy test failed.
Yesterday it passed, so it can work.
I was in an open field with just a few small trees a bit further.
On the X-Hubsan app it showed between 9 and 12 satellites.
I have a GPS test app on my phone and that gave 7 satellites.
But what is the test doing exactly?
Does it look where the drone is or where the phone is?
Or does it look how far the distance between the phone and drone is?
It is quite annoying if you see so much satellites and it still doesnt pass the test.
Maybe some developer can answer this?
GJ
From 0 to 300 km/h in 3 seconds
F5B class modelplanes
www.f5b.nl
Re: What does the GPS accuracy test test?
Post by Hubsan-Ailsa » Wed Jul 25, 2018 11:13 pm
Hello,for the accuracy test,kindly follow the reminding showed on the phone and walk around then you can pass the accuracy test successfully.
gjvo
Contact:
Post by gjvo » Wed Jul 25, 2018 11:48 pm
That is not the answer to my question.
I ask what it tests.
GJ
www.f5b.nl
Post by Hubsan-Ailsa » Thu Jul 26, 2018 6:38 am
The accuracy test which used for the follow me ,orbit and way point function more accurately.
gjvo
Contact:
Post by gjvo » Thu Jul 26, 2018 9:40 am
OK, so than it looks at the distance between the drone and the telephone.
I want the technical answer, i want to understand how it works.
GJ
www.f5b.nl
akifoktar
Post by akifoktar » Sat Jan 12, 2019 12:50 pm
Accuracy test is buggy. very often It never accept the accuracy unless restart the app again and again. It reduces the motivation at the begining of flight. Takes time to hang on this problem. I think accuracy test is ponitless should remove this test.
Post by Hubsan-Ailsa » Mon Jan 14, 2019 1:50 am
Hello akifoktar ,
May I know your phone model number?The GPS accuracy test pass time has something to do with Phone model number and local interference.
