Problem with Hubsan h501s advanced
Posted: Sun Jul 22, 2018 10:54 am
by Gianki
This is the procedure that I used to upgrade, as you can see the FC can't upgrade with V3 Tool but it can be upgraded with V1 Tool. The TX with V2 tool works. RX (third step) with V2 Tool doesn't work as you can see in the attacched video and I can't go on with the procedure. I think that there isn't communication between drone and the transmitter. Let me know where the procedure fails! Thanks in advance!
Re: Problem with Hubsan h501s advanced
Posted: Sun Jul 22, 2018 1:24 pm
by h501sam
have you tried re binding the drone to the controller? :?:
Posted: Mon Jul 23, 2018 6:34 am
If your drone is H501S, choose the FC-V3 firmware will be fine.If your drone is H501S-S,then choose the FC-V1 firmware .
Posted: Tue Jul 24, 2018 2:07 pm
by Gianki
As you have seen in the video, I used FC-V3 but it doesn't work. Why doesn't it work? P.s.: the drone is H501S
Posted: Tue Jul 24, 2018 5:29 pm
by Hubsan-Anne
Use the H501A tool for the RX as well.
Posted: Tue Jul 24, 2018 5:30 pm
by Hubsan-Anne
Posted: Wed Jul 25, 2018 3:41 pm
by Gianki
I tried as you said but it still does not work.
