Mi lehet a hiba? Megvásároltam, kibontás után ezt tapasztaltam.
What can be the fault? I purchased. After extracting this I experienced.
Re: H906a hiba
Posted: Sun Jul 08, 2018 11:27 pm
Hello,this is not the fault.Try to rebind the drone to the transmitter as attached below
Press ENTER button and power on the transmitter simultaneously until"Bind to plane"displayed ,then power on the drone,and place it very close to the transmitter,the binding will be completed after one“beep”heard.
Re: H906a hiba
Posted: Mon Jul 09, 2018 2:39 am
by Aboman
Kedves Alisa!
Próbáltunk mindent. Csak a bot kalibráció érhető el.
Dear Alisa!
We tried everything. Only remote control calibration is available.
Re: H906a hiba
Posted: Mon Jul 09, 2018 11:44 am
by Aboman
Sorry Ailsa. You name is Ailsa, not Alisa...
Re: H906a hiba
Posted: Mon Jul 09, 2018 10:45 pm
It's ok .The issue shows you didn't bind successfully.I noticed that you didn't power on the drone.would you mind to try to power on the drone at the same time?
Re: H906a hiba
Posted: Tue Jul 10, 2018 2:00 am
by Aboman
Dear Ailsa!
I tried several times. Last night my colleague sent an email in connection with an update. The power source does not connect with the specified button + stick+ switch. I don't know what version it's on. I bought it for a week now, and it didn't work right after unwrapping. There was no update. The device may have damaged during the shipping?
Re: H906a hiba
Posted: Tue Jul 10, 2018 11:26 pm
Hello,I noticed that you power on the drone firstly and then switch on the transmitter.It is a wrong operation.
Firstly Press ENTER button and power on the transmitter simultaneously until"Bind to plane"displayed ,
Secondly power on the drone,and place it very close to the transmitter,the binding will be completed after one“beep”heard.
Hope will help you.
Re: H906a hiba
Posted: Wed Jul 11, 2018 1:07 am
by Aboman
Hi!
No binding, no flash mode. Only calibration mode is available. It does not react to anything else. The LED is illuminated orange-yellow. No beeping sound.
I tried...
https://youtu.be/_IUQFtiIuKA
Here is similar to the error
https://youtu.be/LOsI0fASp3A
Re: H906a hiba
Posted: Thu Jul 12, 2018 12:01 pm
by Aboman
Hello. I wrote YouTube to the video owner. He said there was a problem with the 2, 4GHz units. A transmitter is good after replacement. Should I replace it?
Re: H906a hiba
Posted: Fri Jul 13, 2018 4:50 pm
by Aboman
OK. I upgrade the transmitter. The version is 1.1.16. After the turn on, the screen is black. No binding mode. What shuld i do?
