H501A and HT011A flight setup.
Posted: Sat Jul 07, 2018 3:15 am
Can the H501A and HT011A controller be setup so the H501A is binded to the 2.4G portion of the controller and the WiFi portion of the controller hooked up to the integrated relay of the controller. In this config you would get the range of the 2.4G connection and the FPV thru the relay.
I assume you would connect the smartphone to the relay of the HT011A and connect the APP to theH501A Wifi connection. Will this work and not override the 2.4G bind?
I assume you may loose waypoint capability in the APP?
I have looked at numerous YouTube videos and read Hubsan manual re: the HT011A and this is not 100% clear.
