Problemas con el H109S Pro
Posted: Sun Jul 01, 2018 6:35 pm
by Peregrino
El H109S Pro 3 Axis gimbal se desvinculo del mando.
No lo puedo calibrar y no responde al mando.
Como puedo configurar el dron y el mando para que funcione.
De donde puedo bajar las actualizaciones, si esto resuelve el tema.
Lo compre en abril y como es invierno en mi paĆ­s no lo pude usar.
Agradezco me digan que debo hacer para solucionar el problema.
Muchas gracias desde ya.
The H109S Pro 3 gimbal axis disconnected from the control.
I can not calibrate it and it does not respond to the command.
How can I configure the drone and the controller to work?
Where can I download the updates, if this resolves the issue.
I bought it in April and since it's winter in my country I could not use it.
I appreciate you saying what I should do to solve the problem.
Thank you in advance.
Re: Problemas con el H109S Pro
Posted: Sun Jul 01, 2018 11:19 pm
Hello,for the issue that the 3 axis Gimbal doesn't respond to the command.How do you connect the 3 AXIS Gimbal to the drone?would you mind to show picture and video for us?
