Circle me and follow do not work
Posted: Mon Jun 25, 2018 8:25 am
by ccamer
hi
just purchased a new H501ss and am experiencing problems with circle me and follow me
neither of them work
long press of the Video button just stops the video and downward press of rt stick shows follow me mode but the drone does not move.
tried taking GPS mode off and the drone just started flying away
thanks
Re: Circle me and follow do not work
Posted: Mon Jun 25, 2018 8:57 am
would you mind to show the firmware version of your drone for us?Thanks
Posted: Wed Jun 27, 2018 7:56 am
by ccamer
hi
i checked with the information on the FB page its ok but :
V4.2.28
LCD V1..3.4
501ss V2.1.29
FC V1.1.41
CAM v30.84.84
thanks
Posted: Wed Jun 27, 2018 10:40 pm
by clustermarc
Hi ya, make sure you keep the gos on. But also make sure you put the drone to its recommended height and distances for the modes, it should pop up on the screen before you activate it.
ATB Marc
Posted: Wed Jul 04, 2018 4:54 am
by ccamer
hi all
i have made sure distances were ok and follow me will work intermittently. cant say i like having to depress throttle while pressing down right stick to enter the mode but can not get circle me to work at all
Posted: Wed Jul 04, 2018 8:21 am
Hello,for the follow me and circle function,the drone should be at least 10 meter from the transmitter.
Posted: Mon Jul 16, 2018 7:25 am
Hubsan-Ailsa wrote: ↑Wed Jul 04, 2018 8:21 am
If not mistaken there is a height limitation for these to work. If you are too high the initiation of this option will cancel. It will also cancel if you use the joysticks to adjust height or direction after starting either one of them.
Try flying H501S
10 meters away and no more than 20 meters high in a clear field to test again.
My H501A followed and circled me at 10 meters and 20 meters high until I moved the sticks.
