Other problem with updating firmware
ak78
Post by ak78 » Wed Jun 20, 2018 10:19 pm
Hello..
I am trying to update the FC and RX firmware on the H109S unit. For the FC there are no constraints, but for RX I can not go through step 3. The method is to update RX via Remote Control. There is a warning in the windows app (I forgot what was the warning) and on the controller screen the timeout appears.
Currently my drone is on a blue led lighting condition on the front right wing (upgrade RX mode) and there is no way to re-boot the unit.
Is it possible that I can update RX on H109S using the same method and application as Hubsan 501A / 501S without going through Remote Control (of course with RX corresponding to H109)?
Thank you in advance.
Re: Other problem with updating firmware
Post by Hubsan-Ailsa » Fri Jun 22, 2018 6:41 am
Hi Sorry there need to update RX via Remote control and drone.
Would you mind to show the video for demonstrating your operation?The way to post video as attached below.Hope will help you find the issue.
https://www.hubsan.com/forum/viewtopic.php?f=9&t=372
nj1harley
Post by nj1harley » Sat Jun 23, 2018 8:48 pm
Can you tell me what was the firmware version you were updating to? I am having an issue with gimbal control.
