Problem with Hubsan h501s advanced
Gianki
Post by Gianki » Wed Jun 20, 2018 12:37 pm
Good evening,
it's the first time that I write on this forum, which I found very interesting, for a communication's problem between transmitter and the drone.
I've updated the firmware (downloaded from the Hubsan's official site) but, after updated the drone with the file H501A-FC-V1.1.41 and the transmitter
with the file H906A-TX-V1.1.16, at the third step the procedure doesn't go on, because the transmitter doesn't detect the drone. When I turn on the drone, lights are pink of which two are fixed, one flashes slowly and the other flashes faster. I also tried the connection with the "Bing to plane" function but nothing happens. I have read that the same thing has already happened to someone. Could you give me some indication? Thanks in advance!
Re: Problem with Hubsan h501s advanced
Post by Hubsan-Ailsa » Wed Jun 20, 2018 9:51 pm
Try to close the transmitter to the drone.If still fail to work,Kindly show the video for demonstrating the issue.
The way to post video as attached below
http://www.hubsan.com/forum/viewtopic.php?f=9&t=372
