Good evening,
it's the first time that I write on this forum, which I found very interesting, for a communication's problem between transmitter and the drone.
I've updated the firmware (downloaded from the Hubsan's official site) but, after updated the drone with the file H501A-FC-V1.1.41 and the transmitter
with the file H906A-TX-V1.1.16, at the third step the procedure doesn't go on, because the transmitter doesn't detect the drone. When I turn on the drone, lights are pink of which two are fixed, one flashes slowly and the other flashes faster. I also tried the connection with the "Bing to plane" function but nothing happens. I have read that the same thing has already happened to someone. Could you give me some indication? Thanks in advance!
Problem with Hubsan h501s advanced
Re: Problem with Hubsan h501s advanced
Try to close the transmitter to the drone.If still fail to work,Kindly show the video for demonstrating the issue.
The way to post video as attached below
http://www.hubsan.com/forum/viewtopic.php?f=9&t=372
