Binding the Display Screen Video Goggles Pack HS001 to H501A
surquizu
Post by surquizu » Tue Jun 19, 2018 5:30 pm
Hi,
I bought the Display Screen Video Goggles Pack HS001+HV002. I have a hubsan H501A and an advanced transmitter (H906A) with firmware versión 1.1.16. I can not bind the display screen with the quadcopter and the transmitter. I follow the instructions to binding of the hubsan official video (https://www.youtube.com/watch?v=LDuHvn-xSGo) but I can not get it. The screen works well, because I binded to GPS Watch (HT006). In the video it is linked to the standard command and H501S. It possible binding to H501A and H906A transmitter? How is it done?
Re: Binding the Display Screen Video Goggles Pack HS001 to H501A
Post by Hubsan-Ailsa » Tue Jun 19, 2018 9:51 pm
Yes,The HV002+HS001 can bind to the H501A+H906A. would you mind to show the video for demonstrating the issue?
The way to post video as below
http://www.hubsan.com/forum/viewtopic.php?f=9&t=372
surquizu
Post by surquizu » Wed Jun 20, 2018 2:18 pm
Hi Ailsa
In the video you can check how I follow the steps of the official hubsan video and it does not bind to the H906A transmitter, but it does bind to the GPS watch.
Post by Hubsan-Ailsa » Thu Jun 21, 2018 5:35 am
Hi,
Thanks for your video
So Sorry the H906A transmitter can't work with the HS001.
The H901A and HT011A can work with the HS001.
surquizu
Post by surquizu » Thu Jun 21, 2018 10:25 am
Do you know if a next firmware update will work? I do not know if I try to sell the screen and glasses so I do not lose too much money or wait.
Post by Hubsan-Ailsa » Fri Jun 22, 2018 10:33 pm
Sorry for correct one :If the H906A/H901A/H7000 bind with HS001 and HV002 ,you can see FPV transmission in HS001 but there are not right OSD data .
eur_640152Eauv
Post by eur_640152Eauv » Thu Jan 03, 2019 1:26 am
Hello everyone!
I hope someone can me help.
I have a H501A and a Hubsan goggle set (HV002+HS001), but I can’t bind the H501A to that goggle set.
Do anyone know why can’t I bind them?
Any suggestion is well received!
Regards
Alfonso
Post by justjarhead » Thu Jan 03, 2019 8:41 am
Hello everyone!
Regards
Alfonso
What controller are you using with the H501A and the HS001 ?
You cannot bind the HS001 in WiFi mode with the APP. You need to bind the H%01A to either and HT011A in 2.4Ghz mode or to a H901A. I do not believe it will bind to an H906A advanced controller.
eur_640152Eauv
Post by eur_640152Eauv » Fri Jan 04, 2019 2:00 am
Hello!,
Thanks a lot for your help it was very useful for me!
Sadly I Haven’t any HT011A controller, I’ve connected to H501A through the HT005 relay
Due to my unknowledge I supposed that the WiFi and 2.4GHz was the same signal, but now I understood both are not the same signal.
So, I think I have to buy the HT011A controller.
Do you know if after I buy the HT011A controller I will be able to connect to any standard goggles? Or could be I connect to Hbusan goggles set only?
Thanks in advanced
Regards
Alfonso
Post by justjarhead » Fri Jan 04, 2019 8:14 pm
You should be able to use standard goggles but you won't get telemetry info.
The HS001 displays telemetry and can record to its own SD card.
