Battery for Hubsan H122D not charged
Posted: Fri Jun 15, 2018 3:56 pm
by Pick_cz
I got a pack of batteries from here: https://www.banggood.com/Hubsan-H122D-RC-Quadcopter-Spare-Parts-7_6V-710mAh-Li-Po-Battery-H122D-16-p-1257546.html
charged them with the original charger (until the light is solid red) and the voltage on all of them drops from 8.1V to 6.6V in seconds (readings from the LCD monitor). Sometimes the drone even shut itself off on take off. Thats the behaviour of those 4 new batteries in their first attempted flight.
What is happening? What can be done?
Thanks,
Pick
Re: Battery for Hubsan H122D not charged
Posted: Mon Jun 18, 2018 4:20 pm
by vivianfranco
Hello Pick,
Thank you for contacting us. Please contact the seller. By Hubsan Policy they don't cover lipo batteries under warranty.
Posted: Fri Jun 22, 2018 12:56 pm
by Pick_cz
Alright, I was curious if you have some tips and tricks how to revive those batteries. The seller refunded me and I bought a few more from other place. I hope they will work fine.
Fly safe,
Pick
Posted: Mon Jun 25, 2018 3:26 am
by Alex007
It may be the fault of the charger. I no longer use the stock charger as I found it did not give a balance charge, See if you can get hold of a BC 4S15D charger that gives a proper balance charge through the balance plug.
OK. It is not a HV charger and will cut off at 4.2V per cell but that makes only a very slight difference to the flight time.
