Hi,
Where can I buy batteries for this model?
Can I buy batteries from other parties? I am not sure if higher capacity batteries like 5200 mAh or anything bigger than standard batteries can be used.
Also what connectors type are used in this model, what are they called?
Thanks,
Seb
Batteries H501S
Re: Batteries H501S
Hi,
I bought this one on Gearbest: https://goo.gl/yezW1T
It is not possible to buy bigger capacity batteries for H501S, since the battery fits perfectly into the slot and a bigger one would not fit in it.
The blue connector is called EC2.
Nicola
Nicola
Re: Batteries H501S
Thanks Nicola
I actually bought some on amazon 2x batteries for £20 odd quid, not original but we will see how they perform. We can hardly get 15min flying time out of orginal batterie anyway so it should be good if its even 10mins per batterie, will give us 20mins extra time.
Seb
Seb
Re: Batteries H501S
Hi ,Kindly use Hubsan original battery.which won't damage your drone.
Re: Batteries H501S
Hi Hubsan-Ailsa,
could you please confirm that the ones sold on Gearbest (I mean these ones https://goo.gl/yezW1T ) are the original ones?
Nicola
Nicola
