Gimbal swap on H109s
Hey if I put the higher edition 3-axis gimbal on my standard edition H109s will the wiring and everything sinc up. I was wanting to upgrade my gimbal from the 1-axis gimbal that came with it but don't want to spend the money if the higher end gimbal only works with the higher end transmitter.
Re: Gimbal swap on H109s
If you are asking whether or not the 3 axis will work on the standard- yes, it will. However, the aircraft's flight time will be lower than usual (the 3 axis consumes more power) and you will encounter some limitations in terms of the camera pitch angle (either up or down).
