H107D+ Barometer Issue
Posted: Wed May 30, 2018 3:12 pm
by KevC
I have two H107D+ Quad copters. They were great when I was first learning FPV and I want to loan them to my nephews to learn. Problem is, once I bind either one and activated the motors it goes up and up and up. I bring down a few feet off the ground, let go of the throttle and the same thing happens. Same problem indoors or outdoors. I tried putting in down trim on throttle, that had no effect. Ideally I would like to disable this function and handle the height manually.
I can solder, program, whatever it takes. Is there a way to get this issue resolved. I attached a video to the hubsan faebook page showing the problem. It's a .mov so I am unable to attach it here.
Re: H107D+ Barometer Issue
Posted: Thu May 31, 2018 5:52 pm
by Hubsan-Anne
Hey! Sorry for the late response- one of our reps on Facebook responded to your wall post. She could not find the video you mentioned, though. Could you link us? We'll need to see the response on the aircraft as well as the transmitter screen.
Posted: Tue Jun 05, 2018 12:51 am
by KevC
What kind of video files can I attached to this forum ? I have an .mov and a.mp4, doesn't accept either. How can I get this video to you ?
Btw,
On facebook, I see the video I send last week it's there, I attsched an .mp4 version as well. Let me know if anyone can see it.
Thanks.
Posted: Tue Jun 05, 2018 4:09 am
You can attach the YouTube video
Posted: Fri Jun 15, 2018 1:19 pm
by KevC
This is a link to the video.
https://youtu.be/xeMlhrIWMeg
Looking for a way to fix it or disable the barometer. -- Thanks
Posted: Mon Jun 18, 2018 10:48 pm
by KevC
Were you able to see the video ?
Posted: Mon Jun 18, 2018 11:24 pm
Did you change the new propeller to fly the drone?If it is still going up?
Posted: Thu Jun 28, 2018 11:13 pm
by KevC
What new propeller, what are you talking about. This is brutal, I just want to know how to fix or disable the barometer
, please just give me an answer. Two H107d+ doing exactly the same thing, what the heck do the props have to do with it.
Posted: Fri Jun 29, 2018 4:57 pm
by Hubsan-Anne
Usually, one replaces the entire motherboard, unless you have a newer version of the H107D+ (the barometer board will be a piece separate from the motherboard). Could you confirm whether the aircraft's LEDs come on one at a time in a clockwise fashion, or if three come on at once, then the forward LEDs flash alternately?
Posted: Fri Jun 29, 2018 11:22 pm
by KevC
Thanks Anne.
When I hold the button to turn on the quad, all four lights come on one at a time counterclockwise. When I release the button, the front two leds flash.
Once I bind to the radio, all four leds go solid.
Please let me know the cost for a new barometer or motherboard once you know the version I have.
I can do any required soldering if needed.
Thanks Again.
