H501S Battery charger
Posted: Mon May 28, 2018 7:42 pm
by mrshez1
Hi
When do i know when the battery is fully charged? The led's go from red to green and flash twice and go back to red again, does this mean that the battery is charged or is it still charging?
Re: H501S Battery charger
Posted: Tue May 29, 2018 3:15 am
The battery of H501S will flash red light when charging.and it will turn to solid green light when full charged.
Posted: Thu May 31, 2018 5:46 am
by mrshez1
OK thank you for the information.
I love the drone by the way. I have been taking videos and i am very impressed.
Posted: Mon Jun 04, 2018 4:33 pm
by vivianfranco
Thank you for sharing positive feedback, we appreciate it.
Posted: Wed Jun 13, 2018 10:47 am
by nemo
Je viens de recevoir mon H501S et les voyants du chargeur passe du rouge au vert ( branché plus de 6 heures) et cela sur la batterie du drone et de la telecommande ( batteries d origine reçues avec le drone!!!!!! ) mais rien de vert fixe.
Cela est il normal ?
Posted: Thu Jun 14, 2018 4:33 am
Hi,you mean there is no green solid light on the charger.right?did you try to test the battery by the volt meter?
Posted: Wed Jun 20, 2018 3:44 pm
by nemo
Oui mais le problème vient de la batterie, les cellules ne sont chargées pareil car une cellule ne prend plus la charge. j ai fait marcher la garantie et j attends les nouvelles batteries.
Posted: Mon Jul 02, 2018 5:06 am
by ccamer
hi
the battery charger that came with the drone never reaches a state where the LED stay green
since I purchased another USB charger with additional Hubsan battery the new charger works well and i get the solid green lights.
battery life is also better,
Not a complaint merely an observation
Posted: Mon Jul 02, 2018 11:52 am
by 1530544732808NW
Hello ! there is one thing that I can not do with my Hubsan H216A and it is using my VR viewer because the option does not appear to me, I have seen that many have it , but I have only F, Waypoint mode, Following mode and Orbit mode ( i mis VR mode) . I've tried everything and I hoop is not my "One plus 5" phone that's pretty good. Do somebody know something about it ?
Posted: Fri Oct 05, 2018 7:49 pm
by glgeek
Hi
greetings,
did you solve this issue? my charger does exactly the same thing.
starts out both lights solid red
flash both lights green twice
go back to solid red
repeat
new battery from Hubsan directly. charging right out of the box
2700mAh 7.4v 10C 20Wh
any help is appreciated
thank you
ba
