H502S with H906A Transmintter ?
Posted: Mon May 21, 2018 6:34 am
by LDrone
I have a H906A transmitter and an H502S drone, is it possible to see the fpv camera on it?
I tried, and I can controle it, but the fpv is in black . I trie to serach de 5.8 frecuence on the menu ,but I just see a bit lines on black and white or all in black.
This are the versions :
H906A V1.1.9
H502S V2.1.33
Any suggestion please??
Best regards.
Re: H502S with H906A Transmintter ?
Posted: Mon May 21, 2018 7:11 am
Did you try to use the H906A transmiter to control the H501S?did it still show the black fpv?
Posted: Mon May 21, 2018 7:15 am
by LDrone
yes I did it with de H501A, and I have no problem to see de FPV...
Posted: Mon May 21, 2018 7:48 am
Please try to re-select the 5.8G frequency to get better video transmission.
Posted: Mon May 21, 2018 12:08 pm
May I know if you rebind the drone to the transmitter ?try to press the photo button and power on the transmitter simultaneously。hope will help you.
Posted: Tue May 22, 2018 4:42 am
by LDrone
Hello, first thanks for your time
Yes, I do Bind to plane everytime . I tried to re-select the 5.8 frequency and it sometimes work a bit but finaly its all in black
... (Its not a new drone and it´s been a few months off). I felt the down part of the body shell too hot, in a bit time and without flying, only searching for the good frecuency... Is this normal?
Best regards
Posted: Tue May 22, 2018 8:11 am
Would you mind to show the issue in short recorded video for us?Just for better checking
Posted: Tue May 22, 2018 4:46 pm
by LDrone
here is the video.
https://youtu.be/x2_3aFce2Os
https://youtu.be/mPdSJmiGxx8
Thanks!
Posted: Tue May 22, 2018 10:26 pm
Hi ,Thanks for your video,would you mind to check the light status on the belly of the drone?and test if it can take photos or videos.
Besides,did you try to use the another transmitter like H901A to control the H502S.what happend?does it show the black FPV?
Posted: Thu May 24, 2018 6:26 am
by LDrone
the light status on the belly of the drone is in blue . And it take photos and video without problem... but I still can´t see the fpv...
This week I will try to use another trnasmiter to see what happen...
