HT011A video button in 2.4G mode
Posted: Tue May 15, 2018 7:05 am
by silverghost
I flew H501A with HT011A in 2.4G mode which worked fine. But there was no video on the sd-card although I pressed the video button at HT011A. Does it not work in 2.4G?
Re: HT011A video button in 2.4G mode
Posted: Thu May 17, 2018 6:48 am
by silverghost
Is there no anwer to this question? This is essential. The video (and photo) button of the HT011A should work in 2.4G. Flying 2.4G is supposed to be the most safe method. And if there is no control via any display the buttons on the transmitter schould be relyable!
Posted: Fri May 18, 2018 7:56 am
Yes,the video button can work on HT011A.May I know if you use the 4-32GB SD card with class 10 or above?
Posted: Fri May 18, 2018 11:57 am
by silverghost
Yes, 32GB Class10, Fat32. In the meantime I had some success. First there was a video on the sd-card, which could not be opened. Then in a new flight everything worked as ist should. I could take pictures and videos.
I think the first vid, which not could be opened was due to not stopping the video recording with the button.
