hubsan fpv1 transmitter black screen
Posted: Sun May 13, 2018 7:00 am
by 61yavuz1967
it always stays in this way. There is no menu. Drone is not connected. How can I solve the problem. Video linkte.
https://drive.google.com/open?id=1DkV9A3DGA48CNRYOBIo6aeBxz6lpKjpf
Re: hubsan fpv1 transmitter black screen
Posted: Mon May 14, 2018 6:23 am
did you try to rebind the drone to the transmitter ?Please try to Press the photo button and turn on the transmitter at the same time.
Posted: Mon May 21, 2018 4:34 am
by 61yavuz1967
Yes I tried but it does not work. He's not doing anything.
https://yadi.sk/i/zNpSXgLM3VwRtr
Posted: Mon May 21, 2018 7:20 am
have you tried to re-select the 5.8G frequency which quoted in the user manual?If still fail to work,please provide the QR sticker which pasted on the belly of the drone or the backside of the transmitter.Hope will help you solve the issue.
Posted: Mon May 21, 2018 10:29 am
by 61yavuz1967
the transmitter does not enter the menu. I've tried it many times but the menu does not open. elevator stick for 1.5 second to enter. I do not have a habit although I can apply it.
drone barcode:
https://yadi.sk/i/TfVZfiNf3WJCvZ
transmitter barcode:
https://yadi.sk/i/1OOtksG33WJCzC
box barcode:
https://yadi.sk/i/d7IG3uqN3WJD2n
Posted: Mon May 21, 2018 4:18 pm
by Hubsan-Anne
You're using the wrong procedure to enter the Main Menu. Please power both aircraft and transmitter on; enter the main menu after calibrating the compass as indicated below. See if 1) the FPV comes back when you enter the Main Menu and 2) if you can find any frequencies under the "5.8G Frequency" setting that will give you FPV.
Back to Basics #19: How to enter the Main Menu of your aircraft and why you’d want to do it
https://www.facebook.com/hubsan001/posts/1790067991298216
Posted: Sun Jul 15, 2018 8:00 am
by Aboman
Hello! I have this problem. What is the solution? Did you fly with it?
Posted: Mon Jul 16, 2018 5:55 pm
by Hubsan-Anne
Back to Basics #25: How to troubleshoot FPV problems, part 1
https://www.facebook.com/hubsan001/posts/1795789910726024
Back to Basics #26: How to troubleshoot FPV issues, part 2
https://www.facebook.com/hubsan001/posts/1796671740637841
Posted: Mon Jul 16, 2018 6:59 pm
Hubsan-Anne wrote: ↑Mon Jul 16, 2018 5:55 pm
And what do you do if you happen to have the HT011A and the HS001
. Part 1 applies, the GIFs don't help nor does Part 2
Posted: Tue Jul 17, 2018 12:40 am
by Aboman
This is a H906a. You turn it on, and you have a very pretty battery voltage meter.
I can not bind, there is no such option. No menu, black on screen. I think the 2, 4GHz system will be the fault, but no one can confirm it.
