Los motores no arrancan
Posted: Thu May 10, 2018 10:17 am
by Albert501
Hola amigos, acabo de comprar un hubsan h501s y tengo un gran problema, después de seguir las instrucciones y tutoriales oficiales de hubsan, cuando muevo las palancas para arrancar motores NO FUNCIONAN,los motores NO ARRANCAN. He revisado todo mil veces y realizo los pasos correctos. Necesito ayuda por favor!! gracias
Re: Los motores no arrancan
Posted: Thu May 10, 2018 11:33 pm
Why you can't start the motor?
Firstly,check if all propellers install properly.
Then,calibrate the transmitter and rebind the drone to the transmitter as following procedure:Push both sticks to the upper left corner and power on the transmitter simultaneously.the LCD will display 'Calibrate stick mode 2"rotate both sticks in circles for three times ,release both stickers,then press any trim for 1.5 seconds until one "Beep"heard which indicates a successful calibration.
Rebinding the drone and transmitter.Press photo button and power on the transmitter simultaneously until"Bind to plane"displayed ,then power on the drone,and place it very close to the transmitter,the binding will be completed after one“beep”heard.
Thirdly,waiting for the drone picked up 6 or more satellites .
Finally,please remember to do the horizontal calibration which quoted in the user manual.
If still fail to work,please share the issue in short recorded video with us.Let's help you find the issue.
