H501s 5.8 frequency setting
jim99bass
Post by jim99bass » Wed May 02, 2018 5:05 pm
What is the best 5.8 frequency for the H501S. Is there a method to select the best frequency?
Thanks, Jim
Re: H501s 5.8 frequency setting
Post by Hubsan-Ailsa » Wed May 02, 2018 9:21 pm
what is the best 5.8 frequency? Getting the better video transmission is the best 5.8 G frequency.
You can pull the throttle stick to the lowest position and press the Elevator stick for 1.5 second to enter into the Main Menu interface.Push the Elevator stick up/down to select"5.8G frequency",push the stick to the right to enter into the" 5.8G frequency"interface,select a matched frequency.
jim99bass
Post by jim99bass » Wed May 02, 2018 10:46 pm
I have done that and the control shows video from multiple frequencies, how do I know which frequency producing a video is the best one to use?
Thanks, Jim
Post by Hubsan-Ailsa » Thu May 03, 2018 9:23 pm
There is no regular frequency which producing a video is the best one to use.
If you can get a more clearly video transmission.which is the best frequency you should select.
