Hi
So all was ok when I used the oneplus 3t now I've switched to oneplus 6t is there any to know if this phone will be supported ?
Actually I can't even install the app from the play store
So I've downloaded the APK from the site. I've installed and connected to the drone WIFI but the application doesn't detect the drone and it's impossible to connect the app with the drone
Thanks for help
[SOLVED] Support X-hubsan android for oneplus 6t
Re: Support X-hubsan android for oneplus 6t
Hi
Is there any update for me ?
please could you confirm that there is a problem on oneplus 6
Hi
Finally I found the reason why the application was not working with the one plus 6t.
So I give the tip if you're confronted to the same problem
The Phone connect to the Drone but because it doesn't have internet access it consider the connection has failure so it show you a message asking you to confirm that you want to still keep the connection open you must answer the good option to stay connected to the Drone.
When it ask there is a checkbox to not ask again the same question again and again
