[SOLVED] Support X-hubsan android for oneplus 6t
richiesgr
Post by richiesgr » Fri Jan 11, 2019 10:21 am
Hi
So all was ok when I used the oneplus 3t now I've switched to oneplus 6t is there any to know if this phone will be supported ?
Actually I can't even install the app from the play store
So I've downloaded the APK from the site. I've installed and connected to the drone WIFI but the application doesn't detect the drone and it's impossible to connect the app with the drone
Thanks for help
Thanks
richiesgr
Re: Support X-hubsan android for oneplus 6t
Post by richiesgr » Wed Jan 16, 2019 10:09 am
Hi
Is there any update for me ?
please could you confirm that there is a problem on oneplus 6
Thanks
richiesgr
Post by richiesgr » Wed Jan 30, 2019 2:31 pm
Hi
Finally I found the reason why the application was not working with the one plus 6t.
So I give the tip if you're confronted to the same problem
The Phone connect to the Drone but because it doesn't have internet access it consider the connection has failure so it show you a message asking you to confirm that you want to still keep the connection open you must answer the good option to stay connected to the Drone.
When it ask there is a checkbox to not ask again the same question again and again
