H501S-S-H Advanced FIRMWARE
Posted: Mon Dec 24, 2018 5:57 pm
by TreeMGM
I just received the H501S-S-H Advanced with the 906A w/LiPo battery in transmitter. The FIRMWARE is V1.1.17. Do I need to update the FIRMWARE? I appreciate any response you have! Thanks!
Re: H501S-S-H Advanced FIRMWARE
Posted: Thu Dec 27, 2018 4:55 pm
by me_55120Bba4N
Hi I just got the mentioned drone and does not prompt the compass calibration is this normal, have same firmware thanks
Posted: Sat Dec 29, 2018 3:47 am
There don't need to update the firmware unless your drone has specific issue need to be solved.
Posted: Sat Dec 29, 2018 1:35 pm
by ArmyVet
I got this in another post.
According to:
Hubsan-Ailsa » Tue Dec 25, 2018 4:12 am
You drone is H501S-S.the latest H501S-S support compass calibrate automatically.
Have fun with the rest of the confusing manuals and number/nomenclature haha
Posted: Thu Jan 03, 2019 9:33 pm
Yep if the H501S has FC1.1.46 and was bought in the fall it will probably have the Auto Calibrate Compass board.
Even if it has the Auto Calibrate compass you should still manually calibrate the compass at each new flight location. Once done it will remember the compass setting and you don't need to manually calibrate every time.
Don't incline the H501S more than a few degrees horizontally otherwise you will need to calibrate the Auto compass.
Posted: Thu Jan 03, 2019 9:43 pm
by W95
justjarhead... by "new flight location" do you mean your city in general? And, then rely on the autocompass calibrate feature within your locale?
Posted: Fri Jan 04, 2019 8:07 pm
City is too big an area. If you fly in a local park and move to a location a couple of blocks away re-calibrate.
