Battery Questions
Posted: Sat Dec 08, 2018 7:58 pm
by JimW
Hello everyone I have a question about the Hubsan H501S batteries. I have the Hubsan 2700mAh 7.4V 1 0C 20Wh batteries. My question is what do I charge them too and what can the be discharged to? I have a imaX B6AC v2 charger. Any help will be greatly appreciated. Also I would like the same info for the smaller H109A batteries as well. They are the 1400mAh 7.4V 10.36Wh batteries. Thank you for any help.
Re: Battery Questions
Posted: Wed Dec 12, 2018 2:03 am
by PeaUK
this explains it all-
https://rogershobbycenter.com/lipoguide/
Posted: Fri Jan 11, 2019 7:59 pm
by onegoodscott
I would like to know specifics as well on charging this battery and if it can be charged at 1c which would be 2.7 amps
Posted: Tue Jan 15, 2019 8:52 pm
onegoodscott wrote: ↑Fri Jan 11, 2019 7:59 pm
Set you B6Ac to LIPO, 2S, 2700mAh and it will take care of the charging current.
For you 1400mAH battery just change the mAh parameter and the charger does the rest. It will charge each cell and balance them as close to 4.2v per cell that it can get and end the cycle. The C rating i not pertinent to charging unless your fast charging which is not recommended.
Posted: Wed Jan 16, 2019 4:14 am
by clustermarc
See my reply to the post here too, it will also help..
https://forum.hubsan.com/viewtopic.php?t=1490
ATB Marc
