H501A Video Skipping
Hi. I'm having an issue with my recorded video skipping after about 9 seconds. I'm using a class 10 SanDisk 16B micro SD card. I'm flying with the H906A Controller. But even flying with the app, I'm having the same issue. I'm using the latest firmware on my quad and controller. Is there any fix for this?
Alberto
Re: H501A Video Skipping
Please try to format the SD card to FAT 32.below attached the picture for your reference
- SD card format.jpg (16.09 KiB) Viewed 7302 times
The card is formatted to FAT 32, but even though, the video skip continues. You can even see the image skipping on my Transmitter (H906A) screen at close distances even with the drone on the ground. BTW, my computer says that the SD card has an issue after recording from the drone everytime. But when I try the same SD card in another equipment, the SD card has no issues and the computer reads the card with no issues either. I think that this have something to do with the firmware, or the video card (inboard system)is damaged. I've had this problem since new. And for some reason, I can start video recording from the transmitter as normal, but I can't stopped afterwards. I have flown this drone just 4 to 5 times and I still having issues. I'm getting very dissapointed of this product. So I just stop flying this. What can I do?
Alberto
Make sure the Volume Label area is blank. If it's filled in, there will be skipping. I suspect that's what's going on with your aircraft.
Hi Alberto, also make sure its not a cheap clone sandisk card, theres a lot of clone cards about and they are not true spec, my old sandisk card use to skip frames to, i swapped to an offical Samsung 16GB EVO plus 80MB/s MicroSD SDHC UHS-I Class 10 Memory nd my issues went away..
they are cheap so its worth you trying mate even if this dont sort your issues.. this is the seller i got mine from and they are offical..
eBay item number: 222240439842
Good luck mate, hope you sort it..
Happy RC-ING..
Marc..
Happy RC-ING..
Marc..
Hubsan Quadcopters In My Collection So Far:
Hubsan X4 Desire Pro H216A
Hubsan X4 H107C (a few of them)
Hubsan Q4 Nano H111
My Youtube Channel:
https://www.youtube.com/channel/UC9nFqm ... GWmyLnCQ5w
Hubsan Q4 Nano H111
My Youtube Channel:
