H501A & HT011A No wifi LED on transmitter, unable to connect over wifi relay option
Re: H501A & HT011A No wifi LED on transmitter, unable to connect over wifi relay option
Did a test flight with the h216a and the ht011a transmitter and everything worked very well through an old iphone 5s with the latest xhubsan app version 3.6.6. Quad was very responsive without any noticeable delay. Thank You Hubsan for fixing the issues.
Any new features with Version 3.6.6?.
No new features that I noticed other than it working. Maybe the fact that it works is a new feature! Really seemed very smooth and didn't notice any lag through the wifi.
HT011A cannot connect to Wi-Fi to my Iphone XR. No video appears on the smartphone. But I can still fly the drone using transmitter but no video or cannot take pictures.
Can the Iphone connect directly to the H501A?
With the HT011A you should be able to left button to take pictures and right button to shoot video.
What happen when you try to connect IPhone to HT011A?
Camera should turn on as soon as transmitter connects to drone. It doesn’t in my case. Although iPhone indicates wifi connection to both drone and HT011A. BTW there is no microSD installed inside drone yet. Does this matter?
Is the iPhone XR not compatible with latest app version?
Need advice badly! Otherwise I might return the item to Amazon!
I followed instructions to connect iPhone XR to HT501A and will not connect.
Two things:
1. iPhone XR not compatible with Hubsan app’s latest version to HT501A drone.
2. Hubsan need to test if their latest app works with IPhone XR.
Two things:
Here’s what I see on the app.
- 80C98752-5726-4028-906F-AAABC5D7D886.png (782.72 KiB) Viewed 21581 times
As you can see both HT501A and HT011A are connected to my WiFi. But not to the transmitter HT011A. See previous post pics. I really think the app is not compatible with iPhone XR. Am I wrong? Is the transmitter defective?
- 13081484-9706-43F7-9DE8-E86F90E4A8A1.png (223.42 KiB) Viewed 21574 times
