Hello All, I have a H216A with a HT009 remote. The virtual joysticks work fine, but the remote left stick yaw is a problem. A pure left or right movement should just produce a rotation, but on my remote, I get more decent than rotation. So can I calibrate the joysticks on this remote controller? If so, how?
Also, the RTH does not seem to work on the remote - long press produces a beep but the 216A does not return. Fortunately it does work on the phone. There are similar problems with the auto take-off and land. I haven't tried the picture/video on the remote yet,
Calibrate joysticks on HT009
Re: Calibrate joysticks on HT009
I found the calibration technique in the 507A manual which uses the HT009 too. Thanks for all your help.
Hubsan Alisa - I recommend that you add to the user manual of the 216A that section on calibrating the HT009 joysticks that is included in the user manual for the 507A Pro. It appears that Hubsan left it out by mistake.
Yeah but how about actually documenting how to do it. It would help a lot of users who contemplate using the products
Thanks for your kindly suggestion and sorry for the inconvenience
I have forward your ideas to related department.
Further issue or good idea,please feel free to contact us.thanks
