H109S XP Pro Firmware NEED HELP H7000 Transmitter
Larry75
Post by Larry75 » Thu Aug 09, 2018 6:50 am
I tried to update the firmware per the instructions. During the process I lost connection to the Drone and now it wont bind to my Transmitter. No connection to the Drone from my computer via USB cable. I think if I installed the original version of the firmware I could start over. My thought is the firmware on he H7000 is version 1.25 and the drone is something prior. Can anyone tell me what the original firmware version is or if they have had this same issue?
I've removed the batteries, started over like ten times and get to the same point where it wants to bind but never connects.
Re: H109S XP Pro Firmware NEED HELP H7000 Transmitter
Post by Hubsan-Ailsa » Fri Aug 10, 2018 4:42 am
Hello ,
Did you try to rebind the drone to the transmitter?Besides.would you mind to record the video for demonstrating the issue?
The latest H7000 firmware version is TX V2.1.8 or V2.4.8. Can you send me the firmware you updating?
