E501s zakłócenia FPV
D4rus
Post by D4rus » Mon Aug 06, 2018 5:46 pm
Witam nie dawno kupiłem drona używanego nie znam. Jego histori Problem polega zakłóceniach FPV tak to wygląda
justjarhead
Re: E501s zakłócenia FPV
Post by justjarhead » Mon Aug 06, 2018 7:06 pm
Go into menu and change your 5.8g transmit frequencies.
Throttle stick full down and push down the Pitch stick to get into menu.
Use pitch stick up an down to select 5.8G frequency and push pitch stick right to get to frequency selections.
Select frequency and use pitch stick left or right to adjust frequency.
Use pitch stick to select menu exit and repeat until image gets better.
D4rus
Post by D4rus » Tue Aug 07, 2018 3:18 am
Robiłem tak ale brak poprawy
justjarhead
Post by justjarhead » Tue Aug 07, 2018 3:49 am
With the quad powered on and bound to transmitter power off the transmitter and power it back on while holding down the video key.
This will bring up a display of numbers in the middle of the screen.
The purple colored row is the one you are interested in right now.
What is the value of the number on the far right of the purple row. If this number is 0 it could be a bad Transmitter(H901A)
If this number is 80 or above, you need to continue to change 5.8g frequencies.
2xxx 5xxx: xxx is the format of the rssi line. each time ou change frequencies the 5xxx number should change in value.
Let me and Ailsa know what that lin reads as.
If you can, please post in english. Even though I am 1/2 Polish I do not read or write in Polish
D4rus
Post by D4rus » Tue Aug 07, 2018 12:38 pm
Jest około 70 ... Ale jak wciągnąłem antenę 5.8g na zewnątrz aparatury już jest dużo lepiej
justjarhead
Post by justjarhead » Tue Aug 07, 2018 9:20 pm
I did not understand what you said when I translated it.
Sorry
