Following same steps as with h501a, I'm not seeing the 507a in my iphone wifi settings.
Also, please remind me how to calibrate 507a to level?
Much thanks in advance!
rw
transmitter HT011As works w/ H501a, doesn't bind for 507a
Re: transmitter HT011As works w/ H501a, doesn't bind for 507a
Kindly attached the H507A horizontal tutorial video for your reference
Thank you for the link. But, the vid doesn't mention the HT011A transmitter w/ h507a. (I understand what vid covers)
1) can you tell me if the two (HT011A and H507a) play well together?
2) . Is the phone app required to setup the above combo? - I have no problems with h501a and ht011a and the little 6" hubsan lcd display.
Thanks!
r
Thanks!
r
Hello ,the H507A can work well with the HT011A.You mean you can't find the H507A wifi setting on your phone.right?
May I know the lighting status on the belly of the drone when you power on it?would you mind to record the video for us?
Thanks for the reply. Will do!
r
r
