İt is not about zino. İts general app problem i issued my
h216 hubsan drone. Also exist with zino as you can see on review
Hi Alisa,Hubsan-Ailsa wrote: ↑Wed Nov 21, 2018 8:59 pmHello Akifoktar ,
Thanks for your attention of the Zino
For the GPS accuracy test ,which should put the phone and the aircraft together. If both of their GPS positioning are good, the GPS accuracy calculated distance will be less than 5 meters.
If the Phone's GPS is interfered at the time, the GPS accuracy distance between the the phone and Zino will be larger. so the GPS accruracy test can't pass.
Sincerely expected all the Zino Fans get the Zino and experice it by yourself then share your flight exprience on the forum.
I mean dustin video. You can see even if controller and zino are together, app says 10 meters. I had same issuses need to restart app and drone.Hubsan-Ailsa wrote: ↑Fri Nov 23, 2018 1:59 amHello akifoktar ,
For the APP bug review video ,do you mean the Dustin Video or another video?
