hight range flight test
does anyone know how high can the hubsan zino drone go up specs i know its faa rules its 400 feet but i want to know anyway you know someone will go higher than 400 feet thanks
Re: hight range flight test
Your guess is as good as anyone's. I doubt they restrict it to 400 feet since people may want to use this while mountain climbing/biking/hiking and that would suck if you get to the top and can only do a dronie by holding it at arms length or propping it up on a rock.
It will probably only be limited by the battery power and the thin air the higher you go.
Shally Liu send me a answer for my question…
What is the range of Zino?
SHALLY SAYS ; AT LEAST 1 KM
