5.8 ghz goggles
Posted: Mon Nov 05, 2018 9:37 pm
by irussphone
Will the Zino work with my Fatshark goggles?
Re: 5.8 ghz goggles
Posted: Mon Nov 05, 2018 11:27 pm
by ECA77
It will not be compatible with FPV goggles. It transmits the video signal via WiFi.
5.8ghz control and 5.8ghz video transmission
Posted: Tue Nov 06, 2018 12:47 pm
by irussphone
About 30 seconds into the video below...it says that the Zino will have 5.8ghz Control (wifi) & 5.8ghz video transmission (FPV?) as well as HD Wifi video transmission.
I was checking into the Hubsan 501A which uses wifi control and the RC Groups folks say that if you use a regular controller in conjunction with your Phone wifi app, it will do both???
https://youtu.be/WFfXYEFXevU
(copy and paste into your browser)
Russ
Re: 5.8ghz control and 5.8ghz video transmission
Posted: Tue Nov 06, 2018 4:47 pm
by dogstar7
irussphone wrote: ↑Tue Nov 06, 2018 12:47 pm
If you are using the advance controller you cannot use the flight controls of the WiFi app but you can see the FPV. You must turn the advanced controller off to use the WiFi app flight controls and orbit, waypoint features etc.
Re: 5.8 ghz goggles
Posted: Tue Nov 06, 2018 4:53 pm
by ECA77
This is the conversation I had with Hubsan in the Indiegogo campaign comment section:
Eric Crawford
11 days ago
@Hubsan will this be compatible with FPV goggles?
Hubsan Team
Campaigner
10 days ago
Hello Eric,The Zino will not compatible with FPV goggles
Re: 5.8 ghz goggles
Posted: Tue Nov 06, 2018 9:10 pm
by irussphone
Well rats!
Thanks for the reply.
Re: 5.8 ghz goggles
Posted: Wed Nov 07, 2018 1:01 pm
by ECA77
irussphone wrote: ↑Tue Nov 06, 2018 9:10 pm
Well rats!
The only consolation I can give you is that it seems like the app will have a VR headset mode, so you can put your phone in a VR headset and use it for FPV.
Re: 5.8 ghz goggles
Posted: Wed Nov 07, 2018 3:01 pm
by ge_4f3c7hRY3v
yes thercsaylors showed that there is vr mode for phone just put your phone in vr headset im guessing use it for flying the drone with not the app like waypaoint and other features
Re: 5.8 ghz goggles
Posted: Wed Nov 07, 2018 3:50 pm
by irussphone
ge_4f3c7hRY3v wrote: ↑Wed Nov 07, 2018 3:01 pm
Yes and would be hard to do anything but FPV without using the phone and app.
