5.8 ghz goggles
irussphone
5.8 ghz goggles
Post by irussphone » Mon Nov 05, 2018 9:37 pm
Will the Zino work with my Fatshark goggles?
ECA77
Re: 5.8 ghz goggles
Post by ECA77 » Mon Nov 05, 2018 11:27 pm
It will not be compatible with FPV goggles. It transmits the video signal via WiFi.
irussphone
5.8ghz control and 5.8ghz video transmission
Post by irussphone » Tue Nov 06, 2018 12:47 pm
About 30 seconds into the video below...it says that the Zino will have 5.8ghz Control (wifi) & 5.8ghz video transmission (FPV?) as well as HD Wifi video transmission.
I was checking into the Hubsan 501A which uses wifi control and the RC Groups folks say that if you use a regular controller in conjunction with your Phone wifi app, it will do both???
https://youtu.be/WFfXYEFXevU
(copy and paste into your browser)
Russ
dogstar7
Re: 5.8ghz control and 5.8ghz video transmission
Post by dogstar7 » Tue Nov 06, 2018 4:47 pm
If you are using the advance controller you cannot use the flight controls of the WiFi app but you can see the FPV. You must turn the advanced controller off to use the WiFi app flight controls and orbit, waypoint features etc.
ECA77
Re: 5.8 ghz goggles
Post by ECA77 » Tue Nov 06, 2018 4:53 pm
This is the conversation I had with Hubsan in the Indiegogo campaign comment section:
Eric Crawford
11 days ago
@Hubsan will this be compatible with FPV goggles?
Hubsan Team
Campaigner
10 days ago
Hello Eric,The Zino will not compatible with FPV goggles
irussphone
Re: 5.8 ghz goggles
Post by irussphone » Tue Nov 06, 2018 9:10 pm
Well rats!
Thanks for the reply.
ECA77
Re: 5.8 ghz goggles
Post by ECA77 » Wed Nov 07, 2018 1:01 pm
Well rats!
The only consolation I can give you is that it seems like the app will have a VR headset mode, so you can put your phone in a VR headset and use it for FPV.
ge_4f3c7hRY3v
Re: 5.8 ghz goggles
Post by ge_4f3c7hRY3v » Wed Nov 07, 2018 3:01 pm
yes thercsaylors showed that there is vr mode for phone just put your phone in vr headset im guessing use it for flying the drone with not the app like waypaoint and other features
irussphone
Re: 5.8 ghz goggles
Post by irussphone » Wed Nov 07, 2018 3:50 pm
Yes and would be hard to do anything but FPV without using the phone and app.
