Dear Hubsan Fans,
Your long-awaited Hubsan Zino user manual
- Attachments
- Hubsan Zino user manual.pdf
- (1.02 MiB) Downloaded 1418 times
Re: Hubsan Zino user manual
I was just wondering if we could get the user manual sooner. Unfortunately, no mention about the camera settings. At what resolution and frame rate can the drone record in. 4K 30fps ist known, but what about 2K, 1080p? Can 2K be taken at 60 fps?
Will x-hubsan app be completely different? I hope you fixed the bugs on app for better experience with zino. Because i see many bugs when using my h216 x4 desire. When will you release the updated app for zino? Existing app doesnt include zino section.
- rmcbride65
Will the Zino require a compass calibration prior to each flight, or will it be like the new H501S-S with the new compass that doesn't require calibration each time? The manual shows the Zino compass calibration procedure which is the same as the older H501S-S. That seems like a step backwards. Any explanation would be helpful.
Hello
I would like to see a camera swivel, spares to be able to repair if necessary, to be able to change the lighting by the application, it would be a little copy on the Parrot app, activate or not a no fly zone to be able to automatically block the flight during an area Prohibited
befax
