Zino Mini Pro Controller Bricked? HELP ME
me_e3e833yFdR
Post by me_e3e833yFdR » Sun Oct 24, 2021 1:03 pm
I flew one time for 10 minutes some weeks ago, today there was the new 1.13 transmitter update and I proceeded to install it.
After two fails (I don't know the reason of the fails) my controller now is in a strange state, it seems that the battery is in a low status-> I connected the controller to the charger but after one hour the screen continues to show me the low battery icon without the circle that recharge around the icon.
Do you have some suggestions? Is there a way to perform a hard reset or re-install the factory firmware?
I cannot turn on my controller, I see the background light working but no icon are showed by the controller :?
Thanks in advance
SEESN
Re: Zino Mini Pro Controller Bricked? HELP ME
Post by SEESN » Mon Nov 01, 2021 10:10 am
I also don't know why, but the controller screen is black.
I'm very anxious because I can't figure out the remaining battery capacity of the controller.
The screen of the controller was black, but there was no problem flying a drone.
I don't know what's going on after the update.
T.T
Camcast
Post by Camcast » Tue Nov 02, 2021 10:47 pm
Same situation here... a battery icon flashing is the only sign of life on transmitter after a failed update (transmitter fully charged)
I did send an email to support inquiring on this topic.
me_f3ec9slZYF
Post by me_f3ec9slZYF » Sat Nov 13, 2021 11:46 pm
same here.. anyone has already found the solution yet ?
cannot turn the transmitter on if I'm not plug in the charger... once I plugged in the charger, battery indicator blinking only and can't even do anything
me_b2131OB68J
Post by me_b2131OB68J » Mon Dec 06, 2021 8:51 am
I had that once, too . The problem was that the transmitter was not switched off, you could see the backlight very weakly.
After the charging cable was plugged in and the display flashed, I switched off the ender normally. The backlight was then off and I was able to charge the transmitter normally again and switch it on and off.
greeting
horst
me_c07e94cXED
Post by me_c07e94cXED » Sat Dec 25, 2021 4:14 pm
Hello, do you have a solution to the stuck remote control problem ?
thank you
me_586f3OE4ay
Post by me_586f3OE4ay » Sat Jan 08, 2022 8:19 am
I just have had the same problem... or a similar one. After an attempt to install a new release of the firmware the remote control cannot communicate anymore with the zino mini pro or the phone.
Can Hubsan give us a solution to the problem?
Regards,
me_a9d7a4drkp
Post by me_a9d7a4drkp » Mon Jul 04, 2022 5:55 am
Yesterday I had the same.
During controller firmware update, I got USB cable disconnect and 'could not complete update, please restart'
Now controller is dead, only showing batt icon and slight backlight.
Any fix or reset for mini pro controller??
